주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP와 합병하기 전, Compaq은 다양한 노트북 컴퓨터 제품군을 제조했습니다. 현재는 주로 기본적인 기능을 갖춘 제품 위주로 HP에서 제조하고 있습니다.
Why Is My Computer So Slow?
when i wake up in the morning my Compaq Presario is very slow i have to wait 5 minutes just for a program to open up it has been doing this for a long time i used the hardware diagnostic included in the computer everything checks out fine but i want to know how to fix it being very slow i did a clean install of windows vista with the recovery discs that i made when i got the computer it was fine and a month later it began slow again/ i use disk cleanup and disc defragmenter then i restart and it is still slow i have no idea what to do i hope someone can help me i dont think i have any viruses i use microsoft security essentials but i dont know if it works i might have a virus and security essentials might not be powerful enough to detect it but i just want to fix the slowness on it should i recover my system to factory defaults and see what happens
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 1개
i had same problems with my compaq . see if this link helps as it did to me
http://fixingblog.com/slow-compaq-laptop... . thanks
의 공유
댓글 달기
답변 6개
선택된 해법
Hi, One thing to try first is to startup in the safe mode and see if you have the same problem. If you do I would backup all my data to a cd. I would then reformat the drive and do a fresh install of the operating system. I would use AVG Free for my anti-virus (make sure you download the free version). Now before I reloaded any programs or data I would scan them with the anti-virus. I would not defrag more than once every three months and us the disk cleanup weekly. Link for AVG included. Good luck with your computer.
http://free.avg.com/us-en/homepage
이 답변이 도움이 되었나요?
점수 5
댓글 4개:
thank you i will take these steps into consideration i will gt back to you with the results that i get :)
의 공유
hi j713 i'don't have a lot of experience in computer so, my question is where do i find the SAFE MODE where do i click to see it. n where do i go to BACK UP all my data to a cd n where do i go to REFORMAT the drive and do a fresh install of the operating system?
의 공유
Hi, I am including two links to help you. Good luck
http://windows.microsoft.com/en-us/windo...
Second link to follow
의 공유
의 공유
댓글 달기
가장 유용한 답변
this can be fixed . just remove all unwanted programs and run a virus cleaner and make sure you do not have any adware
let me know if you need more help
이 답변이 도움이 되었나요?
점수 8
댓글 1개:
how do I know what to delete?
의 공유
댓글 달기
I agree with RJ713 on what you'll need to do here.
You likely have something running on your system you don't want. Check out this article from Ars Download me II—Removing the remnants of the Web’s most dangerous search terms. Hopefully it will help you in the future.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Interesting article--I have bookmarked it for future reference.
의 공유
Insightful isn't it! We're going to need virtual condoms soon to protect our systems from this filth ;-}
의 공유
댓글 달기
this is how i have fixed my slow computer - first hardware step can be upgrading the RAM .
if you want some steps try these
1- restart the computer and remove all unwanted programs (go to control panel than programs and features
2. cut down some start up programs as they slow computer boot and create problems
3. try updating the windows and reset the browsers for more steps visit post top-10-tricks-quick-smart-steps-speedup-... and see if this post also help you .
please comment below if you need any other help
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Some classic reasons a computer slows down.
1. It's possible that your computer may have so many background programs running that there is not enough main memory to run your main programs.
2. Your hard drive could be too full of data to function efficiently.
3. Your computer could have a fragmented hard drive.
4. If you have 256 MB of free system memory or less, or you like to play games, you may not have enough system memory to run your software efficiently.
5. You could have old or conflicting Windows device drivers.
Let me know if you have any other query.
6. As each new Windows program is installed and uninstalled, it leaves behind parts of itself that can slow down or crash your computer.
7. Your computer could be full of adware, spyware, viruses, or trojans.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Microsoft Security Essentials is good enough for virus detection. Do not worry about that. I would suggest that you restart your computer and scan it with Essentials in Safe Mode. Thats where all antivirus software programs are at their lethal best. Next, you can perform some registry cleaning as i guess you haven't done that uptil now. There are numerous registry cleaners available like Reginout, CCleaner etc which work fine. But remember to always go for the paid ones as free software programs are just a scam 99% of the times. I personally use Reginout and it works well to give a much needed boost to my computer's speed.
If none of this helps then you should back up your data to a CD, format ALL of your partitions on your hard drive and then re-install Windows. And yes, consider using Windows 7. Vista itself is sort of a lagging thing and that might also be a contributing factor to why your computer has slowed down.
Good Luck.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Adam - Did you read the Ars article? Please take the time to read it.
의 공유
댓글 달기
답변을 추가하세요
Sal Torre 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 39,069
