주요 콘텐츠로 건너뛰기
MacBook Pro 15" display 모델
8262 질문 전체 보기
My mac is on, but the screen stays black. Help
Ok. So when I used my mac this morning, it was working fine. I turned it of, then came back to it after lunch. I turned on the mac, i heard the drive start up, and the click you hear when it turns on. The mac was on but the screen stayed black. I shined a flashlight on the monitor, but there was no faint image, and I can't remove the battery because the bottom is a single panel held in place by 10 screws. I really need help, because I use it for homework.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Connect to an external monitor. If it's black you have a GPU/VGC or logic board problem (since GPUs on MacBook computers are integral to the logic board the only way to fix it would be a logic board replacement).
If you see a normal image you should be able to complete your homework. And your problem is with the internal video display chain. This could be a cable, controller/inverter (depending on the manufacture year of your laptop), or the display itself.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
There's another possibility for a dark screen, but only for the non-Unibody models with removable main batteries (2006-2008, Models A1150/A1211/A1226/A1260). These generations also have a replaceable PRAM battery, which helps the computer keep track of the time and screen resolution settings while the computer is powered off. When this battery weakens with age (which usually takes several years), the computer may exhibit one or both of these symptoms:
  • on powerup, the computer will make the normal startup sound, but the screen doesn't light up
  • the clock will be way off, resetting to a time like Jan 1, 1970
Since the default Date & Time setting for later generations of OSX is to synchronize time automatically from an Internet-based network time server, it's possible to have a weak PRAM battery for a long time without detecting it. If you have suspicions. you can switch your Date & Time system preference to manual, then shut down the computer and cold-start it, to see if the clock loses the manual setting.
If it's a PRAM problem, the dark-screen problem is a result of the failure of the computer to send a sync signal to the display at startup. Sometimes you can get the display to light up by starting up with the dark display, then doing a force-restart (Command-Control-Power). The computer may retain enough of a charge from the first startup to supply a sync signal for the restart.
If this is the problem, and you have a non-Unibody model that has a replaceable PRAM battery, you can get the parts and the replacement guides here. In Unibody/Retina models, PRAM power is drawn from the main battery, which remains in the computer at all times.
MacBook Pro 15" (Model A1150) PRAM Battery
MacBook Pro 15" (Models A1211, A1226, A1260) PRAM Battery
MacBook Pro Model A1150 PRAM Battery Replacement
MacBook Pro Model A1211 PRAM Battery Replacement
MacBook Pro Model A1226, A1260 PRAM Battery Replacement
MacBook Pro 15" (Model A1150) PRAM Battery 이미지
상품
$14.99
MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery 이미지
안내서
MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement
난이도:
운영
MacBook Pro 15" Core Duo Model A1150 PRAM Battery 이미지
안내서
MacBook Pro 15" Core Duo Model A1150 PRAM Battery Replacement
난이도:
운영
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery 이미지
안내서
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Would you be able to get an image on your external monitor if you had a weak pram battery?
I tested my pram battery as you suggested. It kept the date/time I set manually through restart. I've replaced the entire display and I still don't get an image on my new display. External monitor works fine. Any suggestions?
First question: Yes, you can sometimes get an image on an external monitor with a weak/dead PRAM battery. If you do a force-restart with the monitor attached, you'll sometimes have enough charge in the system that the external monitor gets a sync signal on the second start.
Second question: If the clock/calendar holds its settings through a restart (and especially through a cold start, when residual charge isn't in play), your PRAM battery probably isn't the problem. You may have a damaged internal display cable, or a damaged display socket on the logic board. It's also possible that the replacement display doesn't work (or has a damaged cable).
If an external display works, then the GPU on the logic board works.
댓글 달기
귀하의 답변을 추가하세요
Maddies12 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 15,085
