주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 11월 Nokia에서 출시한 Nokia Lumia 920은 Windows Phone 8 운영 체제를 사용합니다.
The screen not rotated!
Hi dears,,
When I open any image or the camera of my lumia 920 the screen not rotated between horizontal and position to showing that image in full screen.
But when I open any video it comes on horizontal position and will not back to vertical till I back to the main screen and it comes normally.
Is the rotation sensor damage? or that's a software problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
please follow this steps and fix it.
God bless you
traighten a paper clip and push one end into the small hole at the top of the iPhone. This pops out the SIM card holder. Remove the SIM card. Push the SIM card holder closed.
2
Remove the two screws on the bottom of the iPhone with a small Phillips screwdriver.
3
Look for the seam between the body of the iPhone and the screen. This is found just above the "Home" button. Insert the pry tool in the seam and pry the screen up from the body to expose the connectors. Do not remove it all the way.
4
Remove the two connector wires with the pry tool. Flip the white latch up with the pry tool and remove the ribbon attached to the base.
5
Pull the two black strips of tape off the left and right sides of the screen with tweezers.
6
Remove the five screws holding the LCD assembly to the screen frame of the iPhone. Use the small Phillips screwdriver.
7
Insert the pry tool between the screen frame and the LCD assembly. Pop the screen frame up and pull it away from the LCD assembly.
8
Insert the edge of a utility knife between the screen and screen frame. Pop the cracked screen out of the frame. Remove leftover adhesive on the screen frame with rubbing alcohol and a cloth.
9
Attach the new adhesive strips that come with the replacement screen to the top and bottom of the screen frame. Press the new iPhone screen into place.
10
Reassemble the screen frame to the LCD assembly. Attach the LCD assembly back to the body of the iPhone.
11
Reconnect the connectors, and close the iPhone. Screw the two screws back into the bottom with the small Phillips head screwdriver.
12
Insert the end of the paperclip into the hole at the top of the iPhone. Pop out the SIM card holder. Replace the SIM card and close the holder.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@dr ing ernesto cuadra, what are you trying to accomplish? The phone that the OP is asking about is a Lumia 920, why do you want to replace the LCD?
의
댓글 달기
답변을 추가하세요
Meee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 2,548
