주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
20 질문 전체 보기
Constantly searching for signal.
I replaced the volume/vibrate/lock flex on my iPhone 5 and once I got it back together the phone is constantly "Searching" for the cellular network. Everything else works on the phone. I also noticed that when I eject the SIM card the phone does not display "No Sim" as it would normally. It is an AT&T iPhone 5. Does anyone have any idea what could have caused this? The cell antenna in the bottom right corner is not compromised and the interconnect cables are attached correctly. What else could cause this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 20
댓글 달기
답변 23개
가장 유용한 답변
Hello Everyone.
I work at a IT Repair shop in Portugal and have a lot of experience repairing iPhones.
This started happening to me when iOS 6 came out and I had no idea what was causing this, since the hardware was all ok. Turns out that because the iPhone communicates with security certificates, you have to set the time and date right. Best way to do so is just connecting to a WiFi network and wait arround 5 seconds, then restart the phone. Otherwise, jsut set it manually (the year will be 1970, I think).
Once again, this is the solution for many network issues after unplugging the battery.
Hope it helps :)
이 답변이 도움이 되었나요?
점수 12
댓글 7개:
Thanks to you i fix my problem :)
I did this, but when it comes alive again, it cames No service =/ , but the same sim works im my Iphone 6 Plus (still with the problem), any other solution ?
I reassembled my iPhone5 after chamging the rear housing and had the same issue with cellular signal...This helped,thanks!
Thank you very much,i just fixed my iphone after consistent searching without networks.But after following your instructions network came up.I am grateful.Cheers!
This worked exactly as he said. Thanks a lot. Worked on my iphone 4
댓글 2개 더보기
댓글 달기
I also run it the same problem and did all of tricks in the book... from taking apart the complete phone to checking all of the connectors under microscope and reseting the network settings too... nothing helped...
However the solution was much simpler in the end...
If you disconnected the battery while you were doing any repairs (as you should!) the date on the iPhone should change to the year 1970 or something like that and the connection with the cell tower is not possible... do not ask me why...
After I changed the date I got full reception right away...
I guess it would work if you reset the phone completely since the iPhone would sync with the iTunes on the computer so it should pick up the date too...
Also the connection to the wireless network could also help however at the time I was not connected to the wireless internet at all so I am not able to verify that...
So before you do anything else and have similar "searching" issue check the date first....
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Absolutely correct!
As I stated below, iOS communications systems depend on date/time to communicate.
In normal situations, just connecting to WiFi, would solve the problem.
it resets to thursday the 1st of janurary 1970 at 10.00 am.
in 1970 cell towers didnt exist so it will spend the next 20 to 30 years searching connect to wifi allow time to update then restart phone
댓글 달기
This happenes to me almost every time i fix a iphone 5/ 5s
I always check with soft reset, and reseting network settings. Somtimes i need to start the phone without the sim inside the phone. I have gotten it right in the end every time, but i still get nervous :)
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thank you for this advice. It actually worked!
How Did IT Work i have the same problem !!
댓글 달기
Cycle airplane mode and try again
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Turn off your phone & put it in a plastic bag and close it and then put it in the fridgerator for like an hour or an hour and a half this might seem weird but i swear worked for me
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks. This is weird but worked for me. Cheers!
댓글 달기
having the same issue, replaced the volume power flex with no luck getting the service back, even cycling airplane mode wont work it will stuck on searching, even i tried to look for carriers manual but still can not see any other network..
any advice
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
it resets to thursday the 1st of janurary 1970 at 10.00 am. in 1970 cell towers didnt exist so it will spend the next 20 to 30 years searching connect to wifi allow time to update then restart phone
댓글 달기
I tried to cycle many times with no luck. Even took apart the phone a couple if times but that Did not help eaither. Waited for a couple of hours and the phone tried do connect to wifi. After that it changed from searching to no connection. Then i cycled airplane mode or power. I do not remember which.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I was replacing a back camera on an iPhone 5 and after putting it together the device was searching for service all the time even after the basic troubleshooting tips. I even put the entire logic board in another iPhone 5 that had been working and it is still happening.
Is it possible that their sim card needs to be replaced or the phone needs to be restored?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Had the same issue here.
Solution:
- Recheck the connection of cellular data antenna (Step 15)
- Recheck the connections (Step 18)
Those connectors are tricky (IMHO). Check for damage.- I destroyed one in my old 3GS (pushed to hard) - had to have it resoldered - Be patient and carefull !!! - They have to "snap" in.
- Start the Phone - get your Sim-Card out - plug it in again.
Hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Can you connect to wifi?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I can but I can not connect to any cellular network, there is another thing I notice is that when start the phone for the first time, the automatic date and time zone it keep searching for time and always select the wrong time zone such as Singapore , while I am placed in Yemen,
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Anyone got an answer for this? have you all tried reseting your network? go to settings -> General -> Reset -> Network Reset and let me know if it works
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Nice! This seemed to help.. No "searching" so far...
댓글 달기
I need your help.i have the same problem with searching network .First I put my iphone on dfp mode with the wrong data and time for restoring with iTunes.
But in iTunes when the process is around 70% I have the 47 error-
Why???
Thank you for the future answers.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Sale here. After replace the power /sound flex cable i have a searching network problem. I try everything mentionned here but no way.
So i try an iTune restore and got error 47. I wait the interconnect cable to see if it could the cause.
If someone has an idea :)?
Thanks CcHuMi.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Iam getting frustrated. My iphone 5S cannot seem to detect a network. I have tried hard reset, airplane mode, resetting the network, inserting & removing the sim -- Iam trying to restore it through itunes and it comes up with an error.
Help someone please!.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have this same problem with my 5c. I recently repaired a phone that is locked to ee. Me being on ee thought I could use this phone but I kept getting searching and occasional signal. I rung up ee and they to me that because I have a T-Mobile SIM card I have to get the phone unlocked which they won't do as its a second hand phone. Does anyone know if getting it unlocked will fix this searching problem as I am unsure?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My problem was similar. "Searching" was on top left corner. ATT store switched sim cards with no luck. So I turned phone off. Removed Sim card. Started phone w/ Sim card out. Put SIm card in when phone comes back on and it worked!! Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem after replace the batrry
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
check your time and set it correctly... either sync with WiFi
댓글 달기
I have similar problem for andoid, the cellular networks is searching and accidentally turned off how do I turn the cellular networks back to the automatic can someone help me please.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why Apple didn't give us the solution? All we have same problem my phone from 3 days searching cellular
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yes I don't understand why Apple will not answer all these problems, maybe its because they don't have the savvy or knowledge to give a fix, I believe that it is a motherboard problem and Apple don't want anyone to know this or they would have to recall all the iPhone"s with this problem. I restored my phone in iTunes because of the searching problem thinking this would solve the problem, but alas no way. I have tried all of the options suggested on this problem page but to no avail. This is my first and last iPhone I will ever use, because it is in the bin. Apple you are not a very customer friendly company or you would give out solutions to fix the iPhone.
댓글 달기
Iphone 6 - Removing the sim card, powering off and back on, and reinserting the sim card resolved this issue for me. I have had the same issue sevral times before and had to call my carrier to resolve. They did not give specifics but they stated this was a known issue with Iphones. Twice they had me restore my phone and then said they reset something on their end as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Only way mine stopped searching and connected is if I slam it into my open hand real hard a couple times and it will work for a day or 2 then back to searching so slam it again, something is loose or?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I put mine in the road, went upstairs to my bedroom window and sat with a bowl of crisps and a bottle of cola. It wasn't long before a good sized car came along and obliterated the cunting thing.
Problem solved.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
tommycook 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 108,769
