주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 M8541 / 5GB 또는 10GB 하드 드라이브 / 물리적으로 돌아가는 스크롤 휠
New battery not charging
I have a 10 gig, 1st generation iPod (yes, from 2002!) that won't charge. I bought and installed a new Newer Tech battery. When I plug it in, it powers up and the battery icon shows it charging. After a few minutes the screen goes blank. When it is disconnected from power it is dead. I have restored from iTunes and hard reset with no success. (BTW, when I hard reset while connected to power (press and hold menu and play) the screen goes blank, then momentarily flashes the dead battery icon, then the apple logo and powers up.)
Any ideas? Could the "new" battery be old and unable to charge?
Thanks for your help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Sounds like the case. Although the connection to the rest of the iPod may be incorrect, you could try opening it up and checking that
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a thick, I think 1st generation, classic wheel iPod. It was a gift so other than knowing the HD is 20G and it is thick, I do not have any other info on the specifics of my iPod.
Anyway, I have used it a lot and the last time I plugged it into my computer, iTunes wanted me to do a factory restore. I did than and now the device wants to be plugged into a 110 outlet. I have done that but the icon of it being plugged into the outlet still remains on the screen.
Any suggestions?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
you need to use the original cable and fire wire wall plug …
(USB WON’T WORK)
I have done it many times it work fine after that….
I know this an old post but most iPod users i have met will hang on to a broken iPod in case some day the answer shows up….
의
댓글 달기
this is no an answerer , i had the same problem, and i can not see how to power on.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
(USB WON’T WORK)
의
댓글 달기
답변을 추가하세요
bigvoice 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 4,509
