주요 콘텐츠로 건너뛰기
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
18 질문 전체 보기
What is the battery model number?
Did you find out what model battery the 4th gen Aiport Extreme uses? Would be helpful to list as part of the required tools/parts.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
rockja, looks like a panasonic br2330
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
my airport extreme got dead no lights nthn. tried to change the as well but still it remain the same .. help me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The battery is only for the memory/BIOS settings for the device.
The unit runs on a 12vdc adapter. Check the output of your adapter with a meter and verify the voltage marked on it.
There is probably a SMT fuse on the board near the plug. It should be labeled "F1" unless there is more than one fuse. You could check to see if that is blown and replace it if you have a solder iron. Set the meter to OHMS and touch a probe to either side of the device. A good fuse will show 0 ohms.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
rockja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 403
