주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
질문 마감됨
Track pad does not select
I have a Macbook pro 17in and my mouse moves around on the screen, but does nothing when clicking or selecting an item.
I checked to see if the battery was swollen, and it is not.
I believe I need to replace the track pad, but I'd like to make sure before doing so.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Yes you'll have to replace the trackpad but you can also use the tap function that act like a clic. Check the trackpad module in system preferences.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Remove the battery and adjust the trackpad adjustment screw.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Like mayer said, try adjusting the trackpad adjustment screw, but give it a couple of tries before giving up. It takes a while to calibrate to were the trackpad clicks again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 199
