주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
iPhone 4S keep searching for network after replacing battery
I just replaced my 4S battery myself. the issue I'm facing after doing so is to have my iPhone keep searching for the mobile network. Even after fixing the date & Time, and reseting the network setting the issue has not been solved yet.
Any idea what is the problem????
does it has anything to do with WIFI connectivity? my WIFI router has just gone out of order tonight :(
Anyone have any idea to retrieve the mobile network without having WIFI connected?
HELP ME PLEASE
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
I have restarted my iphone 4s and I want to activate it but the network is still searhing even if I removed the sim card in it.
Please I need help what do u think will be the solution?
댓글 달기
답변 13개
선택된 답변
Guys, when you remove the battery in an iPhone 4/4s, it resets the time and date to somewhere around 1970.
You have to change the time and date to "right now", then restart, and it will work.
This might fix your problems.
해당 답변은 도움이 되었습니까?
점수 8
댓글 6개:
Thanks buddy it works...:)
You can also toggle on and off airplane mode
It worked... Thanx.
not working.
mobile getting automatic restart
silly :) changing date to current worked. Just restart after you change the date. thanks a ton.
댓글 1개 더보기
댓글 달기
As some people have already suggested, first try switching on wifi, if that doesn't work, try changing the date and time manually to the correct ones as it will likely have set itself to Jan 1970 or something similar when you took the battery out.
If neither works, also try checking the cellular antenna and that it's in the right place (NB. the pics in most of the guides on here actually have it in the wrong place - it needs to go around the left of the standoff then to the right of the metal finger)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes, it was very helpful, thank you very mutch.
댓글 달기
You could try a restore in iTunes that fixes the problem most of the time but if you have no internet iTunes won't work as it needs internet connection
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanx for the reply. It didn't help.... :(
all apps and wifi working fine but no cellular network is detected....
댓글 달기
Turn on airplane mode then wait for a while before turning it off again works for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Change date work!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you can follow this guide (it will tell you the needed parts, tools, and steps) to replace the battery. https://www.youtube.com/watch?v=_sUv3sQb...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same problem but I noticed a tiny part was missing near the port connection on the motherboard!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When it's not the time/date thing in the 4s, then it will be pry damage from removing the battery. Look for missing components along the edge of the board
jessa
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Do a restore and use WiFi to activate, while it searches for the Apple server insert sim before next option. Do this fast
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Easiest way to do. Use your friends iphone, make a personal hotspot with it. join the wifi created by the other iphone and go reset the date and time by switchin it to manual and back to automatic and it will retrieve the info from your friends iphone network. After this restart phone. I tried my home WIFI and it wouldnt work with that because theres no info for apple available.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Had the same problem, phone picked up the WiFi no problem but continued searching for the mobile network. I was able to make and receive calls the entire time, and it had the correct time and date.
What worked for me: I changed the time manually to a few minutes off the correct time, then turned on the auto time and date. The phone reset the time to the correct value and found the mobile network.
Good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi all, i had this issue recently and none of the above worked for me but what did work was going into setting > general > reset > reset network setting. once doing this phone picked up signal again :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My own is not working even my time and date it right
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Khurram Waheed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 7
전체 시간: 20,951
