주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대(E30) BMW 3 시리즈로, E32 7 시리즈 및 E34 5 시리즈와 유사한 80년대 특유의 각진 스타일을 갖춘 마지막 3 시리즈입니다.
Outside mirrors not working.
The electric outside mirrors are not working on my BMW 325i. I have replaced the fuse and they still don't work. When I move the the positioning knob I can hear something "click" that sounds like its coming from under the hood.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The click you are hearing could be a bad relay, but it is hard to say. If you remove either the tweeter or the small plastic panel (depending on your car's options) at the front corner of the window glass on the door, you will see a three wire rectangular connector. If you have access to a multimeter, you could disconnect this connector and test the wires for voltage by connecting the test leads to the car-side of the connector and activating the mirror switch. If you have voltage, the motor(s) in your mirror are likely seized. If you do not have voltage, the relay in the circuit is probably damaged.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The e30 has a few problems with corroding (or better rotten) connectors.
here is a link to m42club.com
is think that everthing you need is in there - surely, there can be other problems too - but i would first check the connections and the switch
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dave Urban 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 43
전체 시간: 9,996
