주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Incredible 2라고도 불리는 HTC Droid Incredible의 후속 모델이며, 모델 번호 S710E로 식별할 수 있습니다.
Why Battery is not charging fully?
Hi,
My incredible S doesn’t charge fully, max can charge 47% only, after that there is no improvement keep showing amper indication only, I have tried with 3 ROM but result is same. Then I have changed battery still same, I tried in different way to charge my batteries fully (2 x new battery) then insert in, still result is same. Someone please help me what could be the problem? Why phone doesn’t charge/show to 100% and not turn it to Green. Is phone main board problem? Or better change the phone? I am totally struggle with this phone. I suspect power IC is a problem. what is the solution for it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
May be that where you charge the fone from are missing its 'Teeth' i would advise you to take it to get seen to as i had this problem with an old fone. And it was soon sorted :) I hope this helps you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Sir, jab apna mobile phone htc s710e charging ke liye lagata hon to indication a jati hai but battery ki parcentage nhi bhadti hai.
plz reason bta dein.Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
spb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 1,999
