주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
Loose Screen / Screen popping out
I have had a phone shop replace the lcd. Now the top of the screen or glass moves in and out of the frame as I push on it. It appears as if there is some dark yellow glue behind the screen. The guy at the phone shop re-heated and tried to stick it back down. He also noticed some of the screws were loose and tightened them. Unfortunately the screen still moves just as much. What is the reason my screen has come loose and what should I do to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개
The solution, from what i have gathered is this. The glass extends up past the lcd screen and any screws/ solid attachments to the frame, which is why the top of the screen could be lifted. The lcd has double sided tape around the edge to stick to the frame. In this case the tape sucks, you can feel it move . The phone shop glued the top edge of the screen into the frame. Problem effectively solved.
Note. the glass was lifted somehow by shop leaving another 2 airbubbles but apart from going good
Why replace a good screen? The glass in my S4 is in good shape and is still adhered to the LCD display. The glass/LCD assembly just pops out of the frame and needs to be glued back in to edge of the frame. Can anyone advise?
That right. Reglue yes but better to get the double sided adhesive incase the glass breaks in the future. Easier to replace
댓글 달기
답변 7개
가장 유용한 답변
Did he do a glass only or a full lcd replacement
이 답변이 도움이 되었나요?
점수 1
댓글 10개:
Yep. Full lcd replacement. I did watch a video and it looks like the side bevel and middle housing bolt to the screen. So... how the screen is moving in and out?.. I can use my fingernail and pull the top of the screen out and see behind it to cables from the front facing camera etc. He has used a second hand bevel, not my original and it is warped slightly and cracked at the volume button. The middle cover doesn't move it is firm to the bevel.
I think he has used your mid frame then and not a lcd with the mid frame attached..
Hi Con, thanks for your reply. From what I am understanding so far: the circuits attach to the lcd, then the plastic cover and bevel go on. It's not my aluminium bevel I know that much, this is one he had lying around. The plastic that covers the circuits and holds the battery may or may not be my old one. What holds the lcd in place? How is it possible I can put my nail under the screen and pull it away from the bevel and the plastic a few millimetres??
Another thing; -at the top of the glass in between the front cam and motion sensor there is an air bubble/sepperation. And another above the speaker. Maybe it was done trying to install it to the dodgy housing? Why would he heat it up and try to stick it back down? If it was the glass that was moving you would see air bubbles, glue etc. right?
If you could post a pic if would really help
댓글 5개 더보기
댓글 달기
I have a Galaxy S5 and my screen is like popping off from the left. Now it's slowly starting to pop off from the point to the home button. Can anyone tell me why it's happening?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
What’s the fix for a lifting screen? Will super glue do the job?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
My phones screen is loose
댓글 달기
i have the same problem with my galaxy alpha phone! the top right corner popped out in a matter of weeks and the process is speeded up by tapping the bottom side of the display, eg. when typing sms or more pressure typing moves! i have send the phone to warranty these days and will come back with details about how they repaired the screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same problem here with a 2 month old Galaxy A5 2016 (SM-A510f) sent it in for warranty fix. and it just came back after 14 days and I turned it in just again because the display was set in very poorly with gaps at each side. I really don't know why Samsung-Service sent it back like this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a Galaxy S4 and the bottom right corner of mine is coming up and I need to figure out how to fix it. I can see light when it is pulled up. My phone still works ok but getting tired of having to press it back together only for it to pull apart again within minutes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mine is doing the same, i have some flickering happening as well
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brendan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 32
전체 시간: 63,726
