주요 콘텐츠로 건너뛰기
A popular graphic calculator released by Texas Instruments in 1996.
12 질문 전체 보기
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
댓글 달기
답변 2개
선택된 답변
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 10
댓글 8개:
Holy $@$* you just saved my life
thank you so much
Thanks! That worked great
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
Just reset the calculator!!
댓글 3개 더보기
댓글 달기
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
댓글 달기
귀하의 답변을 추가하세요
Janessa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 46
30일 전: 178
전체 시간: 24,334
