주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1996년에 Texas Instruments에서 출시한 대중적인 그래픽 계산기입니다.
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
의
댓글 달기
답변 2개
선택된 해법
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
이 답변이 도움이 되었나요?
점수 10
댓글 8개:
Holy $@$* you just saved my life
의
thank you so much
의
Thanks! That worked great
의
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
의
Just reset the calculator!!
의
댓글 3개 더보기
댓글 달기
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
의
댓글 달기
답변을 추가하세요
Janessa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 45
전체 시간: 26,000
