주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google에서 출시한 1세대 인터넷 스트리밍 기기입니다. 2013년 7월에 출시되었으며, 모델 번호 H2G2-42로 식별할 수 있습니다.
Red light no matter what?
Hi, I have a google chromecast and when I set it up everything worked perfectly. I unplugged it for the night and then I plugged it back in and it had a red light. I tried factory resetting it but the light still stayed red and the reset button is not stuck. Anything that I can do?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
Try swapping out the USB cable that comes with it, apparently several people were given a cheap faulty USB cable that would stop working after a day or two. Many have found salvation by using a known good USB cable. Let me know if this doesn't work. Oh as far as the reset button you should feel a definite click, if you don't press the button repeatedly to loosen it up.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Changing the usb cable worked for me. thanks so much!! such a simple solution but had me stumped. thanks again.
I have an original 2013 Chromecast and it just stopped working now - July 2022! I know this is an old post, but just commenting as I came across this, and tried changing the cable as a last attempt before throwing it away and it worked!
댓글 달기
Hi
Mine did the same. My Ccast remained plugged in and working great for a few months. Then one day, I noticed the LED was off.
I have tried many power supplies and cables. No luck. Even with a USB inline volt and ammeter plumbed into the supply. It shows no current draw from the C-cast.
Anyone else have this. ??
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i am using the chromecast 2 audio only mode with 4k hdmi converter, red light always blinking bt it extracted audio perfectly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
When I turn on the chrome cast the white light is blinking. But it is not showing in my device
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ted Mayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 36
전체 시간: 27,306
