주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z는 2013년에 출시된 안드로이드 기반 스마트폰입니다. 5인치 풀 HD 디스플레이를 탑재한 Xperia 제품군 중 가장 큰 스마트폰 중 하나입니다. 모델 번호는 C6603/C6602 등이 있습니다.
How to fix the power button spring
Hi I recently had the screen of Sony Xperia Z replaced. Everything is working great expect the power button seems to have lost its spring. You have to place some pressure on the button for it to work since it is now sunk into the housing. What could I do to repair this since it it most likely something missing behind the metal bracket which holds the button housing in place inside the phone.
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
Have you moved the switch flex cable like that when replace the screen? Or did you remember you replace the LCD screen only or replace the screen with the frame? Because replace the screen with frame, you must remove the flex cable.
In fact, there is nothing between the power button and flex cable except waterproof seal. The seal can't be moved, so i suppose your flex cable get loosen or didn't put it in the right position.
You have to open the phone again and to check what's the problem. Have a good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for your response. I replaced the LCD with frame. I thought there was something I lost between the flex cable and waterproof seal of the power button. I will reopen and check again.
의
Hi I lost the Ring around power button. And after that power button become sensitive and being pressed just by little shake or touch on side. Is it due to ring ?
의
댓글 달기
I have had same problem with my sony xperia T2 ULTRA. I tried everything from format to factory settings to restarting from SIM tray reset button but did not work.
Finally I opened lid and poked the button and and mechanism from inside of phone softlywith a needle then it turned to normal. Button is losing it's function or sticking to area where power comes then not working properly.
This is the problem.
Now it is working fortunealty.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi...I faced an issue of "Power button " not working....so unable to Switch ON Mobile , if it get's switched OFF..Pls give any solution
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
have same problem
의
댓글 달기
답변을 추가하세요
aaaaaaaaaaaaaaa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 22
전체 시간: 36,375
