How do I keep I waterproof
How do i replace the full housing with all side flaps and chassis while keeping it waterproof
좋은 질문입니까?
좋은 질문입니까?
First, buy the original full housing replacement with adhesive sticker.
Then, prepare the back cover adhesive sticker you need, must be original and waterproof.
Next, remove and install the small parts inside carefully and correctly especially pay attention to the headphone jack. If you remove it and you'd better use the glue to fix it when put it back.
At last, press the adhesive stickers between every two parts with much efforts to ensure they are stuck very well.
Sony Xperia Z is not easy to take apart, so be careful enough. Good luck to you!
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 4,592
댓글 1개
thank you.i already have the original full housing.that was really helpful,i understand that the trick for waterproofing is in the adhesive tape.
zein hamza 의
