주요 콘텐츠로 건너뛰기
레이저 센서, 버튼 네 개, 트랙볼
12 질문 전체 보기
scroll ball only works in one direction
I have a mighty mouse and the scroll ball only works in the right to left direction. In older mechanical mice, every so often you needed to take the ball out and clean the wheels that the ball touched on the inside. How can I safely take the cover off the mighty mouse and check to see if the inside needs cleaning?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 4개
가장 유용한 답변
There's another answers topic on this subject here.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
First, try a lint-free cloth with a little isopropyl alcohol or similar on it and rub the ball with it in all directions for a while. Works nearly every time. When my mouse acts up i'm sometimes a bit sloppy and just rub it over my trousers which works just as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Eventually even the trouser trick wont work. Follow these images to see what you need to do. Its not that hard, but you need a little glue when you are putting it back together.
http://www.applematters.com/index.php/ga...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
use a vac over the ball
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Paul Watson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 6,993
