주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One(코드네임 M7)은 2013년에 출시된 HTC의 플래그십 스마트폰입니다. 이음새 없는 유니바디 알루미늄 프레임, 대형 듀얼 전면 스피커, 4.7인치 1080p 디스플레이가 특징입니다.
Phone doesn't read SIM-card
Hello,
I have a HTC One that does recognize when you insert a SIM card, but it is unable to read the SIM-data.
When you insert a card it shows "Preparing Simcard" but doesn't show provider information and has no reception.
Is this a faulty Sim Card reader?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
my htc one no signal no imei why ?
의 공유
댓글 달기
답변 5개
선택된 해법
Maybe the Antenna is broken, check the connection of the cabels and clips that go to the backcover.
MFG
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Have you tried restoring the phone to defaults ? (don't forget to backup your data before doing this). Some Android users that I know already had this kind of problem and it seemed to be linked to a software problem. You may thy that before starting any repair !
이 답변이 도움이 되었나요?
점수 1
댓글 달기
it didn't help. Maybe I should mention that the phone is already opened.
Is there any antenna in the backcover so the phone cant get the provider information and reception?
the sim slot seemed to be ok because every pin in the cable had contact to a sim pin.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I changed the reader and noticed it was ok. The phone reads the phone number from the SIM card but since it has still no reception it can't receive the provider information. Any solution for this?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
ok go to settings then go to about phone open to operator & it should tell you who the operator is if is working properly. ihave found they take a while to process the sim signal as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Domsk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 10,888
