주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One X는 2012년 4월에 출시된 쿼드 코어 프로세서를 탑재한 최초의 HTC 스마트폰입니다.
My HTC One X screen has just gone blank...
My HTC One X was working perfectly fine but then suddenly the screen went black. I tried connecting it to the charger but the red charging light wouldn't come on. I also tried ringing the phone but nothing happened. I tried holding the power button for about 15 seconds, still no response. The final thing I tried was to connect it to the computer to see if the computer would detect the device however the computer didn't. I don't know what else to do, HELP?!?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 13
댓글 8개
keep holding the power button and the volume up it worked for me
Thank you , Yasa. A great fix. Did the trick !
@Yara Mansour I love you rn I you are my life tbh
This totally saved me! Thanks!
hey guys it worked forme too. since yest night ithad this issue suddenly turned blank. when called said switchoff. but could get whatsapp call, but could not attend. alarm was ringing but could not slide to off. but this trick worked thks very much
댓글 3개 더보기
댓글 달기
답변 6개
가장 유용한 답변
Mine blanked too! This twist thing (below) actually worked:
http://www.htconeforum.com/forum/htc-one...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Great!! Twisting got my black screen problem solved! Thank you for sharing :)
i have the same problem , Adinda Adinda how solved black screen problem
댓글 달기
It seems your phone died for broken motherboard or battery, you need to send for professional check.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Are the local phone repair shops fine? And do you know how much they will charge to repair it.
댓글 달기
You have what's know as the black screen problem, ( I have too) there is a fix but it involves taking the phone apart and putting a bit of paper between a ribbon cable bend. I'm looking for the fix again myself. In the meantime I bought a new phone LG G2, (good phone recommended) I'll post back here once I find the fix, but it's not for noobs.
Found it: http://www.htconeforum.com/forum/htc-one...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hameed_kakar2003@yahoo.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
mine was taken back to china.apparently not even flashing wold help and no one knew wat the !&&* was going on.am still waiting for my phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How to fix htc one x overheating? Touchscreen sutting down automaticly
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Haroon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 42,962
