The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
좋은 질문입니까?
좋은 질문입니까?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
이 답변이 도움이 되었나요?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 9,690
댓글 4개
It will work with A mouse
hmrogers01 의
the glass is cracked will this keep it from working
hmrogers01 의
It isnt working not alittle.
Richard James 의
my screen is cracked and the same thing happening how do I fix this
Fantasy Anime Lover 의
