주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
730 질문 전체 보기
Display screen colors distorted
My little sister dropped my iPad 2 on the floor. The colors on the screen are a bit out of their normal color. The screen looks a bit also like an old version of a t.v. with scratching lines. The keyboard is green. Once you unlock the iPad the screen looks like the colors of a 3-D screen. Help please! http://m.youtube.com/watch?v=UXfSdG-CwYU
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 190
댓글 111개
It worked! Who would think 10 whacks on the back would fix it but it did! Thank you..........
The screen is green. Tapping did not work.
OMG it worked. Thanks
I left my iPad in the car and it overheated then chasing my screen to be distorted in color. I let it cool off for a while in hopes that's what it was. Whacking it really helped. THANK YOU SO MUCH!!
my fathers ipad is doing the same thing like the version of and old tv. Help!
댓글 106개 더보기
댓글 달기
답변 13개
선택된 답변
Before you go replacing the LCD try giving the back of the iPad a solid smack with your hand. There are many cases where the iPad has been dropped knocking the LCD cable slightly loose. Hitting it may knock it back in place. Do a search on this site and you'll see many examples of this.
해당 답변은 도움이 되었습니까?
점수 90
댓글 103개:
Found out from other forums that way to fix it is to turn it over and give it ~10 slaps on the back! Believe me it works ( got it off other forums )
Can confirm the smack on the rear case does work
Lol that worked I can't believe it!
I was extremely skeptical of this, specially because mine seemed to be much more skewed than what others seemed to be reporting. I tried it and it improved drastically but still wasn't back to normal so a few more pops and presto, it was like magic! Who ever said violence solves nothing!
Well this definitely works. Dropped mine just now and was in despair - until I decided to give it some good smacks....and fixed.
댓글 98개 더보기
댓글 달기
A hard smack on the back--left side will set it right---for now. Ultimately you'll need to open that sucker up and properly re-seat the LCD cable.
해당 답변은 도움이 되었습니까?
점수 31
댓글 35개:
thank you it worked
this is not working for me. Do I need to get the cable properly reseated?
Make sure it's on the left side, middle to top. Worked great for me.
Omg it actually worked!!! Don't think this is a hoax--dropped iPad last night and colors were totally off. Three good whacks to the back left and totally back to normal! Wow!
OMG indeed! I dropped it in its case and the colors were totally off, scrambled, it wasn't usable. Ten whacks to the upper middle left and presto! Woohoo! Saved me an expensive repair bill. GREAT advice!!!
댓글 30개 더보기
댓글 달기
So I just knocked my iPad off the side and my screen went very fuzzy and the colours changed,I read this and I smacked it a few times on the back and nothing seemed to have happened,I then smacked all parts of the back of the iPad,I turned it back round and it had looked like nothing had happened however when I was scrolling down to read a few more of the suggestions,I had started panicking at this point however I was scrolling down for more for approxametly 20 seconds,I looked back at my screen to try another suggestion and then it was SUDDENLY back to normal if not better I 100% recommend trying this as it worked an absolute dream for me x
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Did not work for me
It did just wait for a while …
I was reading this and I left safari and boom
댓글 달기
Can I get it changed at the istore? It's less than one year old.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yooooooooo this is crazy but me and my roomate were making crazy videos and my ipad fell...started getting distorted. I thought it was done for. I joked that if i just slapped it like it fell maybe it would magically work. Googled ipad display problems and found this site. Blown away at all the actuall responses to just smack it....butttteerraa ya girl did it and my baby is back in business!!! Took about a min bit it worked!!!!!!!!!! Hallellujah
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You are a life saver. Smacked 20-30 times and left it for over 2 mins aaanddd Its alive
댓글 달기
Someone please I need somebody’s help NOW! My iPad Air 2 just dropped today and I can’t get it fixed, while I was watching YouTube videos, I thought that the colors looked weird, and that was I thought. My entire iPad has been punished with blue, pink, fuzzy green, and red colors. I was looking up here, and the only way is to smack and whack it. I tried it and it can’t do the trick. I did it almost 100 times roughly whacking it, but it just made it worse. Please help me here, I can’t deal with flashing colors.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Mine too!! God! It actually didn't work ☹️☹️☹️☹️ What we do now???
take it in for repair so the LCD cable can be put back in place.
댓글 달기
tried tapping the back of my iphone but it didn’t work at all.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
this is for IPads... the phones are more sturdy and have different set up... take it for repair... to have the display cable securely connected.
댓글 달기
wow, i was starting to panic
i did both a few solid slaps and a few punches (but hitting with the soft squishy part of my fist not my knuckles) but that didnt get me anywhere, so after reading through all these comments i though, every one is saying to hit it solidly on the left hand side, so i took a hit near the bottom and the on the top of the ipad (on the back obviously) with the squishy part of my fist and boom, all the colours clicked back into place
looks live ive got to start taking better care of this thing XD
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Believe it or not,it’s really worked after 10 times of hard smack!Dropped my ipad 2 yesterday and came across this solution!Thanks,God it’s fixed and back to normal now :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Is this a joke??? I tried this - nothing happened except that my hand hurt
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No, try dropping it. Preferably on carpet and not from too high. I thought it was weird too but it worked for me.
댓글 달기
It worked!! Thank you! I really thought it wouldn’t but it did. Thank you so much!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My Grandfathers iPad has weird colors on it it is kinda of like it is inverted but I can still see the original colors I tried hitting really hard on the back multiple times but it is not working and I hit it every where
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just woke up to my 2020 iPad Pro 12.9 doing the same old TV flickering. Give the back 3 smacks with my palm, good as new again! Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Glyzza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 11
7일 전: 73
30일 전: 297
전체 시간: 369,994
