주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One SV는 뛰어난 음질의 Beats Audio™를 결합한 세련된 4G LTE 지원 Android 스마트폰입니다.
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 4개
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
i cant clear my cache in htc one m8 due to marshmallow update
의
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
의
댓글 달기
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
SOFTWARE updating problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nicole Hallett 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 11,046
