주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 9월 10일에 발표된 Apple iPhone 5c에 대한 수리 정보 및 안내서. 모델: A1532, A1456
How can I fix a keyboard problem?
iPhone 5C keyboard will not type certain letters after screen repair. Everything else works fine except for the keyboard. It wont allow me to use the numbers button. Tried a hard reset. Did not work. What can i do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 13
댓글 달기
답변 6개
선택된 해법
If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive.
But really must try a new known good screen first, as this is still the first suspect.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
가장 유용한 답변
Sounds like a faulty digitizer to me, or a poorly seated digitizer connector. Did you do the screen repair yourself, or did you have a repair shop do it?
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
My sreen is smashed but this was happening before i
Smashed it
의 공유
no it was not
의 공유
I had the repair shop to do it.
의 공유
You should tell your shop about it. If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive. But really must try a new known good screen first.
의 공유
댓글 달기
Usually, the problem occurs after a screen has been replaced and the digitizer cable has not been seated properly. You have to ensure the correct sized screws fitted into the correct position. There are four screws holding down the shield that covers the display cables and if you mix them up then your shield and cover will not fit correctly and the cable connectors will move and cause digitizer and screen faults. Uisung #000 screwdriver you can easily remove and refit these screws, if you are unsure the bottom two are the smallest (1.3 mm screws) and then the upper left is slightly larger (1.7 mm screw) and the far right screw is the largest of them all (3.25 mm screw). You can prior to the removal use a coloured marker or pen and colour code the screws to the position they belong to, remember the two lowest screws (1.3 mm screws) are the same size so can be coloured the same. This should help resolve any problems with exchanged screens and cabling to screen faults. Thanks guys
이 답변이 도움이 되었나요?
점수 2
댓글 달기
hello,
this is in relation with touchscreen ic chip when everything is all right...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My keyboard is frozen also screen
이 답변이 도움이 되었나요?
점수 1
댓글 달기
my iPhone 5s I got the screen repaired and the u and n dose not work on the keybord
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
keldavis5 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 31
전체 시간: 31,852
