주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
플로어 램프는 바닥에 세워 두는 조명 기구입니다. 탁자 위에 놓도록 설계된 테이블 램프와는 다릅니다. 플로어 램프는 보통 테이블 램프보다 높이가 높습니다.
Touch activated floor lamp unresponsive to touch
I was foolish enough to buy a cheap floor lamp that, rather than having an on-off switch, is supposed to turn on and off when touched. This touch feature lasted less than a month. I can no longer return it (I waited too long). Any ideas on how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 7개
선택된 해법
Ultimately, I moved it to an outlet that is operated by light switch! There's a good reason this lamp isn't sold anymore...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
The touch dimmer module is an easily replaceable part, available for less than $10 at Home Depot and other home repair stores. Replacement instructions are included with the part. Depending on the lamp, tools involved are very simple. The wiring is usually connected with simple plastic 'wire nuts', so soldering is not required.
The component inside the module that usually fries is also replaceable, but if you are not familiar with board-level repairs, replacing the entire unit is preferable.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Awesome, thanks for the info!
Which component usually fries?
@davidbraver From my experience the part which often fails is the 47uF capacitor in the control circuit. Those parts contain a liquid which dries out over time. the cheaper the part the faster it happens. there is a guide which describes if the transistor is faulty and I left a comment about the capacitor:
터치식 램프 트랜지스터 교체
댓글 달기
Check the connectors inside, maybe something's loose- any chance you can get us a model number or photo or something? Without knowing at all what it looks like will make figuring out how to fix it difficult.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Does it have some kind of external control pad? Regardless of where the touch pad is, if you take it apart it will have a set of wires coming in from 120V AC and a set of wires heading toward the bulbs. Assuming this light fixture takes regular light bulbs (not HID such as high pressure sodium or mercury vapor), you can eliminate the touch function all together and just install a generic I/O switch. Its hard to say what switch would suit your application without knowing the dimensions of the lamp or how it is constructed.
It's hard to tell that I'm a shade tree mechanic, huh? ; )
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i would chech the triac. i can't think of how many i fixed over the years.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Made in China = POS
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Bring it back to manufacturer and wrap it around his head. It will make you feel much better. My bet is that you will have to go to China to complete this errand.
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
Ben Eisenman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 99
전체 시간: 21,144
