주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
질문 마감됨
stuck on battery charging sign not booting into the OS
Hi Everyone!.
So i bought a retina macbook pro 13'' late 2013, the person said it had liquid damage and apple said that it would need the following things to get it working again
Display clamshell
top case
logic board
SSD
I bought it because i got it a bit cheap
so i took out the logic board and the ssd and cleaned it, SSD is fine, it works in my air, the LVDS connector on the board and the lcd was burned pretty bad, i replaced the whole lcd with a spare one i had, (has a little crack, i use it for testing), i wasn't expecting it to work but even with the burned LVDS connector ,the lcd lid up to the battery sign, i was very surprised.
The liquid damage was in the lcd connector area only not through out the logic board**
OK, so the problem I'm facing now, is that the macbook only shows the battery sign when i plug in the charger, it doesn't charge the battery and doesn't have any light on the magsafe, so its stuck on the battery sign.
Any suggestions how i can fix this?, I'm good at soldering, i don't want to replace the board as its very expensive.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Start with a new DC-in board. Cheap and easy... might be lucky and have that solve your issue.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
the power is going into the macbook, doesn't that mean that the dc board is fine?
댓글 달기
Try downloading and running Coconut Battery to get a better idea of where you stand with the battery and charging. I agree with MacHead on replacing the adapter board, it's close to the LDVS cable and is a cheap try.
http://www.coconut-flavour.com/coconutba...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It won't boot up , just stuck on battery sign , I'll replace the DC in and see what happens
Thank you , i replaced the dc in, and now i get orange light, still not charging the battery, i think the logic board is faulty, what part on the logic board can i replaced to get this working?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 3,725
