주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
이미지
이미지
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개:
any solutions ?
yes, I fixed it changing the flex usb charge port
댓글 달기
답변 4개
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Have you fixed it...i have same problem...help
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
답변을 추가하세요
Alexander Morales Sevilla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 2,667
