주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 9월에 출시되었으며, 모델 번호 T100T로 식별됩니다. 쿼드 코어 Intel® Atom™ 프로세서와 2GB RAM을 탑재한 2-in-1 휴대용 기기입니다.
How Do I Remove my Broken Screen?
I cracked my tablet screen and I have a replacement. but I cant seem to figure out how to remove the cracked screen. To clarify only cracked the glass (I think its called the digitalizer) not the LCD. Any tips?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
You have the back of the tablet off, unplug everything carefully then heat the frame up (careful to not melt it) and use a safe opening tool to peel the frame off the digi.
Hope this helps!
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thanks alot! i found sombody on you tube. but i mess up the glue when i went to put the new one into the frame so now it dosent lay flat but it seems to work fine anyways.
의 공유
Jess where did you get the replacement digitizer? And how much did it cost? Thanks! Adam
의 공유
I got mine off of ebay for $57. seems to be working fine so far!
의 공유
댓글 달기
Be careful replacing the digitizer on the Asus T100
They do have replacements on auction sites for around $30-80 depending if its being sent from overseas.
I have had terrible luck with them though -- I think they are all faulty.
Out of the 4 I've received (two shipments a couple months apart) 1 arrived cracked, and the three others all start to show "phantom touches" like crazy not very long after install, which totally makes them useless.
btw -- it costs $130 to return them to china with tracking for a $140 refund... lol... they know what they are doing...
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
that sucks! luckily someone warned me to check where it was coming from an make sure it was from US.
의 공유
Did you ever find a good place to get high quality replacements for these?
의 공유
댓글 달기
can someone tell me where i can get a 10.1 transformer screen
daveg002@gmail.com taanx
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I looked on Amazon first thin and found all supplies needed at great prices. Hope this helps. And "how to" videos on YouTube.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jess Savage 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 21
전체 시간: 13,655
