주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ford의 F-150 픽업트럭을 기반으로 제작된 대형 SUV인 Expedition에 대한 수리 안내서 및 지원 정보입니다. Lincoln Navigator와 밀접한 관련이 있습니다.
Why is my driver window not working.
Everything except the driver window works. All buttons and all other windows and locks. It makes a slight sound when i press the window button but it does not do anything.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
could be a bad relay, bad switch or a bad motor. What have you tried so far?
의
I traded out the "switches" on the door panel. That fixed the ability to put all the other windows up and down from each individual door. (I am assuming the "window lock" was broken). Aside from that i have not tried anything else. I do not hear the motor working when I press the button.
의
댓글 달기
답변 4개
가장 유용한 답변
I've had several windows stop working over the years and usually, if I can't hear the motor when I push the switch, it's usually the problem. If I can hear the motor, I assume the relay.
Update
My son in law is a mechanic so we just went to the wreckers and found a replacement motor for my window and he installed it. If I didn't have him to work on it, I'm sure I would have taken it to a professional. Only you know how mechanically inclined you are ;) Best of luck!!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
So it would be best to buy a motor and replace it? Or would it be better to take it to a professional?
의
댓글 달기
My driver side window shattered due to a broken keyed entry. Basically the metal bar inside put too much pressure on the window… And…boom, broken. After that I bought a new window and put it in myself. However, i couldn't get the new window on the track brackets because it wouldn't roll up anymore. After reading this post I have a better understanding of what the problem is. The motor. Thank you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Verificar los fusibles de los power windows si estan todos bien verificar lo botones y limpiarlos con limpiador de contactos (contac cleaner)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Most likely the motor , we have had to repair ours , bought the whole harness and such at cost from amazon and all labor performed at at home
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well probably so the switch is showing power doorlocks all other windows working
의
댓글 달기
답변을 추가하세요
hernan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 8,507
