주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Mighty Mouse에 대한 수리 정보 및 가이드입니다. 이 마우스는 레이저 센서, 4개의 버튼 및 트랙볼을 갖추고 있습니다.
Purchase and replace ball
Something small and hard fell in the mouse track ball area and while i was pressing it (upside down) on a piece of paper to clean it, that little hard piece of dust, carved the surface of my track ball making it unable to scroll without jumping around!
So im now in the need of purchasing a new ball and replacing it! Does the ball as a part exist? Because i can't find anything on ebay! Any help?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Does anyone know how to find the provider of the scroll ball Apple uses to equip the Mighty mouse?
의 공유
댓글 달기
답변 2개
선택된 해법
Sadly, the Mighty Mouse and the Magic Mouse are deemed as not repairable by Apple. You're only hope here is to see if you can locate a dead one to steal the part to make yours whole again or look into getting a new one.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Where can i look for a dead one?
의 공유
eBay is a good start, local tech flea markets
의 공유
댓글 달기
genik, I am sure that you have already checked these instructions. Post an image of your trackball as well as the damage with your question and lets see if we can assist you finding what you need. If you can measure the diameter of the ball and let us know what you find. the scroll ball is nothing but a "rubber" ball with a metal core. I would suggest to measure the existing ball and get something the same (or at least very close to it) ball from places like this. Hope this helps, good luck.
update
any mechanic or machinist should be able to help you. All you need is a set of vernier calipers to measure it.
이미지
Update (01/06/2016)
I thought by now you had found what you needed. Anyhow, the diameter is 7.15mm/0.2815inch
이미지
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Hmm interesting, only i don't know how to measure exactly the diameter!
의 공유
Is this tool offered in the Pro Tech Toolkit? Cause i see something similar... i think!
의 공유
Has anyone managed to measure the diameter of the scroll ball?
의 공유
genik, I sure would have thought you had it accomplished by now. I do have one left, so let me know if you want it:-)
의 공유
You have what left? A scroll ball?
의 공유
댓글 1개 더보기
댓글 달기
답변을 추가하세요
genik 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 21
전체 시간: 920
