주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼 코어 Intel Core i7 프로세서.
Can RAM be upgraded?
I just got a MacBook Pro and already regret not doing the 16GB upgrade. (For now, it's fine, but I'm thinking about the future here.) Is there any chance this will be possible—at least in the years to come?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 49
댓글 9개
I really need to upgrade the RAM. I have many apps running and it slows down my MacBook pro
의 공유
In this device no, as it is soldered to the main board unless you have someone like Louis Rossmann solder more on.
의 공유
Now I think of buying another laptop. My macbook pro retina 13 inch early 2015 still works fine, but I need a bigger screen and a bigger RAM (I have 8GB now). Just checked the apple website for a new laptop with a higher Ram and SSD, the prices are draconic! Shall I go for Windows laptop which can be upgraded with parts at much lower price? My wife bought Windows PC laptop for £300. Couple years later upgraded SSD and RAM and her laptop works fast and good. And the upgrade cost was not noticeable at all. I used to Mac and like it, but feel that the pricing and upgrade ability is unfair. Probably will go for Windows laptop because of that.
의 공유
Yes you can upgrade the RAM on a 2015 MacBook all you have to do is redo the RGB chip with a hot air soldering device. I do it all the time it’s very easy. Also a good way to fix locked boards without passwords by using old dead boards that are unlocked.
의 공유
Can you do mine @josephhefner lol. I have 2 early 2015 Mac pros with Retina display. Both have 8 gb of ram. Since covid everything is moving towards video and I need more ram to run Facebook live and zoom services at my church. I’m in the NY area. If you’re to far away, is there anyway you can make a YouTube video explaining how to do the upgrade. I’m definitely a d.i.yer. My computers would really benefit from another 8gb of ram.
Thanks
Robert
의 공유
댓글 4개 더보기
댓글 달기
답변 11개
선택된 해법
No. This model has 8 GB of onboard RAM by default, but it can be upgraded to 16 GB at the time of purchase—for an additional US $200. The RAM in this model is soldered to the logic board and cannot be upgraded later.
이 답변이 도움이 되었나요?
점수 50
댓글 11개:
Yes, I realize all that. However, what actually prevents a RAM upgrade?
의 공유
De-soldering, re-soldering and locating compatible RAM. I don't even know where the type of RAM required is disclosed... it could be like the Blade drives, there are no 3rd party components available. If it were possible someone here would have created and posted a guide.
의 공유
Good answer, thanks. Perhaps it will be possible in the future. One can hope!
의 공유
While you can't add RAM, you can replace the SSD storage. But, presently Apple is the only supplier of the SSD unit and you would have needed to order your system with it at the time of purchase. With that said, many parts houses have bought units to then take apart for the parts! So it's possible to find a read Apple SSD as a replacement and many 3rd party storage upgrader's like Other World Computing will be offering SSD's soon.
의 공유
FYI: OWC now has drive replacements: http://eshop.macsales.com/shop/ssd/owc/m...
의 공유
댓글 6개 더보기
댓글 달기
Guys... The RAM is soldered on to the logic board and there's no way to replace unless you want to take the risk of unsoldering and soldering new RAM back on the board.
I can almost guarantee that you'll have to buy a new system afterwards because this will permanently damage 99.9% of people systems. If you're really desperate for more RAM on your system you can buy a new logic board. However Apple custom orders these, so you'll have a very hard time trying to get a hold of one.
I'm also in the same situation as you. I bought an early 2015 13" Macbook Pro with retina display and I'm wishing I would've opted for a more top of the line configuration. It really sucks that Apple would do this however they tend to keep peoples devices running smooth with updates and as long as you stick to multi threaded applications and applications from the App store, you shouldn't have any performance problems for a long time. Keep in mind that the system you bought is very capable and is top of the line.
이 답변이 도움이 되었나요?
점수 21
댓글 3개:
So iFixit sells logic boards - does this mean I can replace mine with one that has more RAM?
의 공유
My Mac repair guy replaced my logic board corroded by a liquid spill using one from a supplier from California, so it must be possible! The new logic board is a different clock speed and amount of memory, so yes, this is possible! I paid about $480 for the board.
의 공유
Apparently there are some chucknorrises out there who can do it and make it look pretty easy 😆
https://youtu.be/Cs-aZvWF7BI?si=-9cMPmgY...
의 공유
댓글 달기
Yes you can but you need the right gear, if you want to know more I have two words: Louis Rossmann.
이 답변이 도움이 되었나요?
점수 8
댓글 7개:
No, the ram is coded to pair only with this motherboard. If you do the unsoldering process and add like 16gb of ram from another logicboard, it will not work. I know people who did it. It was working after replacing the original 8gb
의 공유
No, it actually will work, but it takes a bit more than just soldering on new ram. You also have to manually modify the SPD to have the correct settings for the new RAM. Otherwise it'll think the old ram is still soldered to the computer.
의 공유
The correct answer is, YES, it is possible to upgrade the RAM on a MacBook Air 13".
https://www.youtube.com/watch?v=CTsEJ49L...
The real question ist, is it feasible? I still use my MBA 13" in a productive environment. A replacement board with 16GB RAM was cheaper than an upgrade of my original board. Your milage may vary as different service providers charge differently.
의 공유
YES!
I successfully upgraded my 2013 Late MacBook Pro Retina from 4gb of Ram to 8Gb of ram and from 128 Storage to 250!!
의 공유
Hey Kobie. How did you do that ? what did you use? thank you
의 공유
댓글 2개 더보기
댓글 달기
I don’t know if anyone has said this yet it is actually possible to upgrade the ram very easily, all you have to do is find a motherboard on eBay that has 16gb ram and install it
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
Now that is a great idea !
의 공유
I think that it should work because is the same macbook case and like the same board but different processors
의 공유
댓글 달기
It could be done. I’ve seen People from Rewa doing great things. Changing the RAM may involve professional skills in soldering and de-soldering + the change of some components on the board.
Better ask Chinese shops.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Yes. I can and do solder but I think you are right in this matter. I will not try this on my wonderful MacBook Pro.
의 공유
댓글 달기
It can be done on A1502 models, but it requires skills, equipment and the correct 16GB RAM. This repair isn't for the faint of heart and can kill your machine. There's a few manufacturers who make the chips and they're not proprietary. They can be either salvaged from another MacBook or from a inline memory module. The process involves desoldering the existing RAM chips using hot air and resoldering in the higher capacity ones. Depending on the manufacturer, you will also need to either remove or move a resistor location. There's a chart (somewhere online) listing the different RAM manufacturer and the correct resistor configuration.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
everything is possible my man. all you need is the same kind of ram macbook pro retina has (size and speed) and a guide on how to place em in the motherboard (which is the problem). And the stuffs are all glued in. So pulling out stuff to get to the ram is difficult. But do remember you have super ssd and lot faster ram speed to get you through long time to come. Believe me man i went with a 8 gb model of 2015 macbook pro retina 13 myself.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The RAM is *soldered on*. There is no glued in "stuffs" to pull out. Desoldering the RAM DIPP modules from the motherboard and resoldering on new ones is 99% likely to end in disaster for 99.9% of users. It's a *lot* harder than it sounds.
의 공유
No you don't use glue! You need to have the correct soldering tools and a bit of skill! Until you've practiced a bit on some junk I wouldn't make this your first project.
의 공유
댓글 달기
Hola from Mexico City dear "originalmachead" & "Dan". English is my 2nd language so forgive my grammar.
Interesting topic. I have a Macbook Pro Retina 15" launched by Apple at the end of 2013 with no option to add more RAM but with the option to expand it at the time of purchase to 16 GB in RAM.
As far I as know, the same RAM (1600MHz DDR3L onboard memory) is used on all Macbooks after this year until now, so, my question is amigos... can my 8GB of RAM can be de-soldered & re-soldered in order to upgrade to 16GB from RAM taken from a broken/sold4parts late Macbook?
And I say "broken/sold4parts Macbook" because according to "originalmachead" find new 16GB of new RAM is impossible and I quote "I don't even know where the type of RAM required is disclosed... there are no 3rd party components available".... and I agree completely because I have looked for it thoroughly .
Thanks so much for your replies, cheers from Mexico City.
DJ Rocari
www.rocari.com
이 답변이 도움이 되었나요?
점수 0
댓글 달기
DJ Rocari
www.rocari.com
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
As expressed above with the correct tools and access to the correct chips with the needed skills it can be done. I wouldn't make this your first soldering project as it does take a bit of skill.
의 공유
댓글 달기
hi i have a macbook pro retina 13 mid 2014 A1502 and the screen is broken. I found a macbook pro retina early 2015 A1502 Full Lcd Screen Assembly. I use 2015 on the 2014 apple?
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
If I am not mistaken, 2015 screen will not work on a Late 2013 and Mid 2014 Retinas.
의 공유
It's the other way around. The 2015 screen is backwards compatible with the older A1502s, but the older model screens are not compatible.
의 공유
Sorry the 2015 display is wired differently than the older displays.
의 공유
댓글 달기
No, MacBook Pro RAM cannot be upgraded later as it's soldered to the motherboard—choose wisely at purchase.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ernest Surudo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 34
지난 30일: 201
전체 시간: 751,701
