주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei Ascend P7은 2014년 6월 Huawei에서 출시한 5인치 스마트폰입니다. 모델 번호: P7-L10, P7-L00.
Black screen Huawei p7
My huawei p7 has a black screen and it doesnt respond anymore when i hold the power button it vibrates 1 time and when i put it in the charger my red light works on the phone and i dont know what to do because my warrant is not valid anymore somoene can help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 22
댓글 20개
Similar problem. The phone does not power on, I just have the front led flashing a red light, then an orange one , and eventually a green light.
의
I have the same problem.. please help!
의
Me too have same problem... I am worrying a lot. Just used for a month and now no more use :(. Even in warranty, I am in USA and no service center too :(
의
Buddy, the screen itself not turning on but inside I feel it is functioning, if some one calls it is ringing but I could not seen anything in display. It is totally black
의
댓글 15개 더보기
댓글 달기
답변 10개
가장 유용한 답변
I had the same problem and just opened the sim and sd cards and put them back in again. It came back on again. What a relief!
이 답변이 도움이 되었나요?
점수 6
댓글 7개:
Thank you so much. Problem solved.
의
i tried but same problm
의
worked as soon as i took out the cards
의
I will try this, I hope it will work
의
i have tried all the methods nothing worked even toke the battery out nothing work still the phone is working but black screen
의
댓글 2개 더보기
댓글 달기
my phone have a this problam
helllllllp
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I had the same problem.my phone doesnt switch on and its only blinking in red
Please help.thanks
의
댓글 달기
Remove the back cover to check if the screen connector gets loosen and try to re-connect
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
and how do you do that?
의
yeah his right, how can you remove the back cover ?
의
댓글 달기
guyz my screens only shows up during calls and when i unlock my phone. After unlocking my phone the home screen gets black and can see the bottom 3 options and can use the top slide as well but can't assess the app's that are on home screen ??? plzz help me out
이 답변이 도움이 되었나요?
점수 0
댓글 달기
lol i just changed my home screen style from top slide setting and issue resolved : D now.
no more black home screen............... wew
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
really, that great
의
댓글 달기
You need to flash your Huawei P7 Device using P7 Firmware, download P7 Firmware from google, and flash with that. Can you access to "Recovery Mode" ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I can her mine but I can't see nothing
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my Huawei p7 lite is black screen can’t open but I charge the it have the led light and sound others things is nothing just the screen always black screen.how to fix it
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have exactly the same issue ;(
의
댓글 달기
Please my Huawei Phone is on the power button isn’t working, the phone is on, as I keep hearing notifications but can’t open it, HELP!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
ASSALAMUALAIKUM in my p7 phone there is a problem the problem is my phone is not charged and not open some days ago my phone is on but there is a line colour green but my phone is not on plz help me
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
MsMoha1997 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 32,641
