주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동명의 사회적 기업에서 제조한 스마트폰입니다. 더 공정한 휴대전화 대안을 만들기 위한 첫걸음입니다. 2013년 12월에 출시되었습니다.
Touchscreen fails after reassembling
My Fairphone has been fixed before and ever since the lens of my camera was dirty. Today I cleaned it, following assembly instructions on Fixit. However, my touchscreen fails so I can't use the phone anymore. Do you know what I might have done wrong in putting everything back together?
Thanks, Annemiek
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
I also had problems with the digitizer after a day in wet conditions. After some hours on a heater it worked again, but only sporadic. So I disassembled it a little bit to get to the digitizer-plug and cleaned the plug.
When water has been in an electric device, the problem is not the water, its the salt, and that remains even after drying.
And with new moisture,even if its just a little bit from the air, makes an short circuit again.
So far, after cleaning the phone workes:).
Josch
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi, I now have the same problem. Do you know ho to fix it yet?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Unfortunately I had to buy a new screen... Now it's perfect again but I hope you can solve it in a cheaper way. If you happen to live in Amsterdam, ask the Fixables in de Rijnstraat. These guys are great! Good luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
allways make shure to fix the digitizer plug properly after replacing the motherboard!!!
Maybe consider Step 19 here: You have to hold the motherboard perpendicular to the dixplay unit and plug the digitizer plug.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
AnnemiekvanB 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 24
전체 시간: 1,225
