주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 Apple iPad에 대한 수리 안내서, 분해 정보, 문제해결 정보를 제공합니다. Wi-Fi, GSM, CDMA 모델이 있으며 저장 용량은 16, 32, 64 GB입니다. 2011년 3월에 출시되었습니다. 모델 번호 A1395, A1396, A1397로 식별할 수 있습니다. 일부 모델은 iPad 3 출시 이전에 새로 고침되었습니다. 수리가 어렵고 열과 분해 도구가 필요합니다.
How to fix green/purple screen
I am in the process of a ipad 2 screen repair and I have two brand new lcds. For some reason one displays a tinted green and the other tinted purple, I have tried every method I know to resolve this problem. Now im looking for advice on what causes this issue. Would great if I can resolve this today
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 5개
선택된 해법
Since no answer has been accepted yet, let me share my experience:
A/ First thing I try is disconnect then re-seat the Display Cable on both ends (using this guide): on the logic board and on the LCD. Then secure the connectors with Kapton/Polyamide tape.
B/ I test the contraption by:
1/ Gently re-seating the LCD back in place then flipping it again out of the back-case. In other words, I am causing the display cable to twist slightly and gently, and putting light stress on both connectors, to see if the change in hue occurs again. Please be gentle ;)
2/ Tapping slightly on the back of the iPad, especially around where the display connectors are located.
C/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
D/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the display cable.
E/ I test again (repeat B)
F/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
G/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the LCD.
From experience, 95% of cases are resolved without having to change the LCD.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Hello I good smack on the rear case will fix a wonky coloured display..
Same thing happened when I was repairing one today even after a reseed of the connector it was a green screen. So I lifted it up and hit it a smack on the back and normal screen functioned..
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Thanks for answering, ill give it a try tomorrow
의
Cheers keep us updated
의
Still not working I tried your method. Its not a loose connection or a grounding issue so I'm stuck
의
If a really hard good smack does not work then it needs opened up and the lcd disconnect and reconnected if still a funny display after that then the lcd has gone bad
의
I tried 2 lcds. One shows purple and the other shows green. The only thing I haven't tried is to restore the firmware.
의
댓글 1개 더보기
댓글 달기
I went to the Apple Store and they took out my screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The screen on my Apple IPAD2 changed from blue to pink/purple. Please help me with this problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi,
Usually that problem is due to a bad connection of your iPad's LCD, what has to be done is:
- turn off your iPad;
- open your iPad (please watch the repair guide related to it);
- carefully disconnect (on both ends) the flex cable shared by the LCD and the Logic Board;
- carefully reconnect it, make sure it is well connected;
- try turning on your iPad to check that it is working properly.
If not than you should need a new LCD.
Hope it helps :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
matthewlevy300 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 26
전체 시간: 31,382
