Why some keys not working
some keys of keyboard not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개:
same problem occurs on the lenovo ideapad 110-15isk
the H and G keys dont work along with the " and esc and some other command keys, is there any fix to this problem please tell me!
의 공유
If some keys do not work properly on your laptop (for instance, C, M,Q,V keys do not type at light touching - you must press them hardly and longly - some 3-7 seconds), then all suggestions to reinstall the keyboard driver and so on are rubbish.
The solution is as follows: Just open the bottom of your laptop, remove the battery (or lift it) and unfold the soft bands under it (or fold them otherwise).
I had 2 Asus laptops of different models and that action resolved the problem in both. Usually that problem arises 3-rd year of laptop's use
의 공유
Hi osama nasr,
Wich keys are not working? Could you be more specific?
Bye!
의 공유
having same issue the g and h keys not working and track pad intermidently stops untill i press a key
의 공유
the keyboard touchpad should stop working while keys are activly being pressed,
의 공유
댓글 달기
