주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Where do I get the inside LED light for cheap?
My IPhone 5c is water damaged. I recently gotten the phone given to me and it was water damaged when I got it cause I thought it would be fixable. I went to a guy the fixes them and he said it'll cost about $200 to fix it, because it's risky. I can't send it in because it'll cost more than he's offering, but that's a little too pricey for me. I can't find anywhere online on where to get the inside LED light for the screen, because it's what brings up the picture on the phone. I recently bought a battery thinking that, that was the problem and he explained that it wasn't the cause.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sara Tackett, just to clarify. You bought a water damaged phone to have it fixed by someone else? You want to change the LED inside the display? This is just for clarification purpose. My answer to you would be that you will be better of to replace the complete display, then to attempt to change the LED. Right now you are going by the assumption that it is the LED that does not work, your problem may actually be a problem with the backlight circuitry on the logic board etc. You may need to do more troubleshooting.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 919
