주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Western Digital My Passport 드라이브. USB 3.0 휴대용 외장 하드 드라이브.
My passport fails initializing
My passport 1TB ran for more than a year under windows 7,8 and actually 8.1, but suddenly stopped. it loads the drivers but doesn't appear in the explorer. when I start the disk management it indicates that the second disk (my passport) must initialize. but it fails.
it appears in the device windows , just doesn't start (or initialize). I even tried the refrigerator trick, nothing
I've also tried several data recover progs, recuva , testdisk, easyus, wondershare WAC, etc, they all fail to see the external drive.
there must be a program that can go through , any ideas?
thanks, Jim
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 20
댓글 6개
Just tried R-Studio, it sees the disk, but cant read it
의 공유
I was able to see the data inside the HDD with a linux version included in the Hiren's 15.2 CD also i could copy some files I needed but with 0 KB no luck yet, still working on it.
의 공유
2tb western digital my book, same problem, R-Studio brings up error 1117. Spent 3 days now trying to recover
의 공유
This problem is also with me too
의 공유
Hello, one could solve it?
의 공유
댓글 1개 더보기
댓글 달기
답변 8개
선택된 해법
This may still be true. Try wiping the drive on a Mac and use the "write zeros" option. Used to be that if the boot blocks on an IBM went bad it was unusable with Windows but can be fixed on a Mac.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
there was some data that I would have liked to recover there. but if there's no other way. will try it as a last option. tnxz
의 공유
@mayer I fear that won't work on a Passport. These are custom amalgamations of a SATA and USB port. The enclosure itself is the drive. You can't even take it out and put it in another enclosure.
의 공유
댓글 달기
The only 2 possible suggestions that may work are:
a) Solder on a new USB port.
b) Find a logic board for the matching drive. Hopefully you can find one with a SATA connection.
If you can get a working SATA port, then recovering may be possible.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
this problem can't fix by any software...
you must repair the hardware of your WD HDD !!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
HOW can I repair hardware in a hdd??!! You need highly specialized equipment
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same whith me sombody can help please?
Thank you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Everyone,
this problem is because of firmware corruption of WD Hard disk drive that must be solve by Hard Repair Equipment like a PC3K ( a expensive hard repair hardware! ) but you can give your Western Digital hard disk to a HDD Data Recovery company to bring the information to you and do a hard repair for your precious Hard Disk.
i have that equipment and can do for you without any cost dear,
Hard Repair Company in IRAN
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Right! We are going to send our HDD s with our data to IRAN!
의 공유
Yes dear,
We will repair your Hard disk without any cost
의 공유
댓글 달기
Try WD SmatWare Installer. if you can get to where it asks for Password type in 5 wrong answers it will then ask if you want to reformat say yes and you will lose all data on the drive but have the drive initialized and back working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jimlberto 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 44
전체 시간: 30,759
