주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JAKKS Pacific에서 제조한 이 장난감 야간 투시경은 실제 야간 투시 및 동영상 녹화 기능을 갖추고 있습니다. 수리에는 스크루드라이버와 지렛대 도구가 필요하며, 일부 수리 시에는 교체 부품이 필요합니다.
Why won't my goggles turn on?
When I try to turn on my Spy Net goggles, nothing happens. The device was working fine yesterday, but it seems like everything on the device just stopped working. I can't see anything on the screen inside, and the buttons don't even make the "beep" sound that they make when the device is on.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
If you’re getting absolutely no response from the device, the most common answer would be that the batteries are dead. You can access the batteries by unscrewing the back panel of the device. If the batteries are not dead, then the problem must with the internal components of the device.
This could also be due to bad connection of the wiring that gives power to the device from the batteries. The wires might be severed or detached from their terminals. Check out this troubleshooting page for more information.
One last reason for the device not responding could be due to water damage to its critical components. This does not means that the device had to be completely submerged in a pool for water damage to occur, but this could have also happened if the device was left in a humid setting, in mist, etc. There are some remedies that might be of use if the device was not completely submerged that can be found here.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Justin Diehl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 4,747
