주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4인치 디스플레이 / 다양한 색상으로 출시 / 3가지 모델로 출시 / 16, 32 또는 64GB 용량
iPod will not turn on?
I was using the iPod Touch (16GB, no camera) when it suddenly turned off and would not turn back on. Tried charging it for several hours and no change, it still won't turn on. Could it be the battery needs replacing? Seems the logical place to start but wasn't sure?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 6개
가장 유용한 답변
Try the easiest first....try cleaning out the dock connector with some canned air to see if there's anything keeping a good connection from being made. If that doesn't work, open it up and see if anything has come loose/broken etc.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Have you tried plugging it into the computer to see if it registers? If it gives you an error, maybe google the error to see the meaning. Just a thought
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
i have the same problem with mine. t does not register when i plug it into the computer, also the home button did not work prior to this. Help?
댓글 달기
was there a solution? if so please list what it was. Thank You!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
mine dosnt reg wen plug into laptop either
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Long time since this was posted, but I had a similar problem. iPod would not turn on, nor take a charge.
I was able to fix it by plugging it into a power source then pressing the home and power button and holding both for about 30 seconds. The Apple logo popped up and it would now take a charge and power on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How do you restore iPod when it’s locked showing USB to iTunes and says can’t restore, no network
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kelly P 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 2,920
