주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Button makes electronic "click" sound when pressed
Here's a weird one -- I've got a 14" iBook G4 that makes a subtle electronic click sound when the button is pressed. It also makes this sound when the space to the LEFT of the button is pressed, like just pressing on the plastic of the topcase is triggering it as well. Very odd, I know. The sound almost sounds intentional, as if it's supposed to happen, and it's very subtle and high pitch, like two pieces of glass or metal lightly tapping. It's kind of pleasant, actually. It's definitely an electronic sound.
Anyway, I've had a few machines do this over the last couple years, and while it's not a huge horrible problem, it would be interesting to know what causes it. The machine has a fresh OS, so it's not a tweak to the button settings, etc.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Does it sound like an HDD sound?
when you say "button", are you talking about the power button, or the trackpad button?
댓글 달기
답변 4개
선택된 해법
The way the power button is installed I would suspect a mechanical rubbing and release is the cause of the click. Pressing on the top case would have a similar result I should think. Ralph
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
He says it's definitely mechanical
댓글 달기
If you look in System Preferences>Track Pad>Clicker you'll find the solution. Clicks like the clickwheel on an ipod. OR not, depends on the setting.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
That's a good thought, but I remember checking that, and it wasn't it. The clicking didn't happen all the time. Since I know it wasn't the hard drive either, I can only assume it was some kind of electrical flaw in the topcase. Ah well, I'm not going to lose any more sleep over it unless I come across a similar machine.
댓글 달기
Maybe a simple PRAM reset will work.
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
Tried that, good idea though.
If it's definately hard drive then verify/repair/replace
I'm not convinced...it makes the sound when the button is pressed...I've never known hard drives to make a distinct sound on command.
I have a feeling that he needs to open it up and take a look.
Sorry, I meant to say it's definitely NOT the hard drive, but I forgot the "not". :-) It was a minor issue and I sold the machine, so I'll have to wait for the next one to solve the mystery. Thanks for the brainstorming though!
댓글 1개 더보기
댓글 달기
Now that my trackpad stopped clicking by itself, I'm not sure what's going on. It seems the button to select" clicker" in system preferences enables the trackpad to behave like the select button below it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rdklinc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 29
전체 시간: 2,525
