주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
질문 마감됨
Where to find components to repair logic board
In removing the logic board from my 2011 Mac Mini, a component came halfway off and I can not attach. I am pretty good soldering components, even small ones. However, this part is a two contact component, similar to how larger LEDs are, square, with a contact on each side. One of the contacts actually broke off and stayed on the board and the other side, I was successful in removing from the board without damage. I tried to solder the damaged side back onto the board (to the piece that is still attached to the board) with no avail.
So my question is, without spending a ton of money on another logic board (one for parts, that may have other damage that i could harvest the component from) does anyone know where I might be able to source this component individually? in the image, it is the one circled in red. It appears to have the writing "IR0 216 IJ2" on it.
ANY help would be appreciated!
Thank you iFixit!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
That looks more like a "1R0" that would make it a 1,000nH = 1µH = 1R0 inductor
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Would you know by the markings what the amperage rating is as well? I have found 1R0 inductors online the same physical size but they have amperage ratings of 0.002A up to 4-5A
댓글 달기
Your best bet would be to buy a damaged (for repair only) logic board or machine on e-bay desolder and use that part.
If this answer is acceptable please remember to return and mark it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 252
