주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung이 제작한 Samsung Galaxy R (Royal) 스마트폰은 Android 소프트웨어, 4.2" 터치스크린, 그리고 전/후면 카메라가 특징입니다.
Battery life is less than expected
My phone's battery does not last as long as it used to even when it has a full charge. What can I do to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Reducing screen brightness, volume levels, and number of applications running are all ways to reduce battery usage. Also, turning off notifications from apps like Facebook and Instagram can improve battery life.
If you are in an area with bad service reception, you may want to put the phone on airplane mode. The phone will attempt to boost signal to gain reception, and this can cause the battery life to drain quickly.
Make sure you are using the charger designed for the phone. Sometimes chargers that fit but are not designed for the specific phone have electronic defaults that can shorten the life of your batter. Use the correct charger.
Make sure the battery is connected correctly and that it is clean.
If the above methods fail, I recommend replacing the battery. See this guide on replacing the battery: Samsung Galaxy R 배터리 교체
You can purchase a new battery from SamsungParts.com, amazon.com, or ebay.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Keon Horahan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 307
