주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Problems installing a new HD
I have a late 2009 15" MBP.
My original HD crapped out and I replaced it with a Hitachi Travelstar 750gb / 7200 RPM.
Using Snow Leopard install disc I had troubles formatting the new HD and could install 10.6 when HD was internal.
As a USB HD, I was able to format HD using another MBP, but when I reinstalled the HD in the 2009 MBP, the Snow Leopard install would quit after a few minutes.
However when the HD was hooked up externally to the 2009, the Snow Leopard installed no problem.
Computer performs using new HD externally. Should I expect problems if I install internally.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Can you give us the last four digits of your serial number so we can verify your system. Also can you give us the exact make & model of your HD you are trying to install.
의 공유
댓글 달기
답변 1개
선택된 해법
Probably the HD cable... have a spare on hand when you install the new HD.
FWIW You don't have to completely replace all the reassembly screws. Be careful (starting on a hard surface) to test and see if it will boot. If it doesn't you can swap the HD cable without a lot of extra time and work.
If this answer is acceptable please remember to return and mark it accepted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
chris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 248
