주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung 디지털 카메라 수리 안내서 및 지원.
lens open & close same time
My samsung camera DV 150F as soon as i press the power button LENS opens & close same time and follow message appears on screenTHE ZOOM DIDNT OPERATE NORMALLY INSERT THE BATTERY AGAIN AND TURN THE CAMERA ON IF NOT WORK CONTACT THE SERVICE CENTRE.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 17
댓글 달기
답변 3개
선택된 해법
Raza, first of course you want to follow the instructions given to you regarding the battery. If that does not work, it sounds like you are having issues with your lens not properly extending. You could try and clean it, check to see if it looks center when retracted. Check on here for more information.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try removing the battery exactly as the lens comes out.. it worked for me while all the other solutions failed.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
You saved my life, thanks a lot :)
의 공유
댓글 달기
답변을 추가하세요
Raza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 12,182
