주요 콘텐츠로 건너뛰기
1903년에 설립된 영국의 자동차 제조회사가 생산한 차량 수리 안내서 및 지원.
Is it the resistor thermal fuse?
Hi can anyone help me my heater on my auto Vauxhall corsa d was only working on 4 then it stopped working completely so I brought a new heater motor but now it is only working on 4 again is this this the resistor thermal fuse. please help anyone. thanks kirsty
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hi my Corsa heater doesn’t work at all could it be the fuse if so which fuse is it ?
댓글 달기
답변 2개
선택된 해법
kirsty, there are two common causes of a heater blower fan problem in the Corsa D
1. Faulty Heater Resistor (Part No. 13248240 ) Usually, it is the thermal fuse on it that fails.or 2. The connector on the wire loom connector can become overheated and melt, causing damage to the loom. So take a look at it and see what you find. My money is on the heater resistor thermal fuse. Take a look on here and here as well. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had similar problem on a Vauxhall Combo heater which worked only on setting 4. The answer was a new resistor matrix fitted into a connector just behind the heater body. It is tricky to reach but it works on al 4 settings now.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kirsty 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 12
지난 30일: 49
전체 시간: 33,163
