주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 8월에 출시된 HTC One의 소형 버전입니다.
Powering on with a broken power button
Hello guys, I've been having kind of a big problem with my HTC. I dropped it a few times and the casing tore away from the top part and the bottom part of my phone, including the power button. normally I'd just get a new casing so I could use it, but the mechanism itself tore off too, meaning that getting a new button or casing won't really fix it.
I was wondering if there is a way to boot up my phone through my pc. I've been searching around and it seems to be fairly simple for most Android phones, however, since HTC One's block your access to the battery, I cannot use any of the tips others give me.
I do not have warranty anymore, so I'm not afraid of doing the bigger things. It is also rooted.
Right now, the phone is still on and I wake it up by using lock widgets and using the volume button. I am however still scared about not being able to charge it on time to keep it alive.
Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
i am in your place but it had turned off
댓글 달기
답변 1개
가장 유용한 답변
it's pretty easy if i remember right that power button does not require soldering so just order a new part and pop it in.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
as in disconnect the old broken one and connect that one.
how to reboot my htc one mini not working my power botton
댓글 달기
답변을 추가하세요
Alperen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 3,755
