주요 콘텐츠로 건너뛰기
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 질문 전체 보기
How to fix hard drive?
a message comes up everytime i turn my laptop on saying to back-up files soon or i will lose everything in it! I tried to back it up and it wouldnt let me do it because of not enough memory. what do i do to solve this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
I won't know how full your hard drive is - never had a message like this! are you sure the drive is full?
not that some malware stuff is spitting out those messages!
but if you need to backup your data - use an external hard drive, copy your user data files to that drive (you don't have to copy something like the windows directory to that drive - it's not useful and some files can't be copied when windows is active)
you can also use the backup function that came with windows.
read more about it here (click me)
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
댓글 달기
If this message is showed as the computer is starting up, it means that your hard drive's S.M.A.R.T. is failing which is an indicator that it may be failing. Back up all your data onto another HDD or DVDs. Order another HDD here but make sure its a 2.5" and not a 3.5" however.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same problem here.
i'll follow your tips and buy a new HD.
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
missladyb7697 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,895
