주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 6월에 출시된 Galaxy Mega는 720P 스크린, dual-core 프로세서 및 8MP 카메라를 장착한 6.3인치 스마트폰입니다.
Samsung Mega Black Screen
I recently installed my replacement LCD digitizer for my Samsung Mega. Upon installing it the first time, the screen came on and I could see everything but would not respond to touch. I removed the back and the flex cables and reconnected them, now when I turn the phone on the screen is black but I can hear the phone turning on. Could you possibly tell me what may be wrong?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Thank you for the advice, I will contact the person I purchased it form.
의
댓글 달기
답변 1개
선택된 해법
Hi Brittany
Its possible the connector is not seated all the way and is causing your issue, Check that first.
If that does not solve your problem, its possible that screen has accidentally been damaged. I would test the device with another known working screen, if it works, then yeah the display is bad. If it does not work and its a known working display your testing it with. Then its the motherboard of the device that is not outputting a display and not the screen itself.
But like I said, its possible the new screen went bad. They can be easily damaged during the install process. Also by bending one of the cables to much could have caused damage.
Hope this helps in solving your issue.
V/R
Josh.O
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I agree with Josh This has helped me in the past.
의
댓글 달기
답변을 추가하세요
Brittany 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
All Time: 4,250
