주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MiP 로봇은 2014년 8월에 출시되었습니다. MiP은 어린이를 위해 설계된 인터랙티브 로봇 장난감입니다. 이 로봇은 손 제스처 기술을 사용하여 반응하며, MiP이 주행, 댄스, 게임 등을 할 수 있게 해주는 다운로드 가능한 앱과도 연동됩니다.
MIP bluetooth won't discover
Trying to use bluetooth with my iphone 6 and it never FINDS the MIP---just says discovering over and over...Thoughts?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 7개
How to pair it and is deos'nt register
의 공유
Having same issue. Tried replacing batteries, uninstalling/reinstalling app. No success. Entered a ticket on WowWee's website, but no answer yet. Will post when they do. Please update if you find a resolution.
의 공유
We had the same problem. We ended up exchanging it for a new one. We knew something was not right when it wouldn't connect to any devices including an iPhone 6. As soon as we turned on the new one - it connected to our son's nexus 7. Looks like the Bluetooth was broken in the original mip.
의 공유
Please can someone help me! I need the password for the bluetooth when trying to connect? Any ideas as to what it could be and where i could find it
Thanks
의 공유
does bluetooth on? if not do this scroll down
의 공유
댓글 2개 더보기
댓글 달기
답변 8개
선택된 해법
Try switching Bluetooth on or off in the Settings and try pressing the refresh button in the top right. As mooka1 said, try tapping on the auto-connect screen.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
I have an LG k10 and I am haveing the same pobelm
의 공유
댓글 달기
if its stuck not the search for mip screen (has the mips jumping up and down on it) tap the screen and you should go through to another screen that allows u to pick a mip.
hope this helps.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
The MIP robot is no longer discovered with the Android 8.0 (Oreo) update (bluetooth issue). Already reported to Google.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
This is correct I have android 8.0 and I was able to connect the mip to the app, but after I had to change the batteries the mip isnt showing up on my phone again. Very frustrating.
의 공유
If your mip doesnt turn on with new batteries then there might be a loose wire. I had TO takes the screws out of his back and mess with the wires. There should be a black and red wire (thicker than the other wires) have masking tape on the end of the wires. Tape the wires back to there circuit board and it should turn on
의 공유
댓글 달기
What about pie? Not working on Samsung s9 plus
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I Can't connect my Mip to my phone. It says I need a passkey but it never said that before. Earlier it connected flawlesly. Please help me find a fix.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Yeah me too can someone help . What is the pin?
의 공유
댓글 달기
Try switching Bluetooth off and then on a couple of times. If not the try charging the MIP.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It worked just fine on android 5 untill i put new batteries into mip then its not showing on the app it shows the mip in the Bluetooth menu but it needs a
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I try connecting to Bluetooth and it asks for a pin
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
publicinfo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 59
전체 시간: 33,050
