주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto G (2세대)는 Moto G2라고도 불리며, 2014년에 출시된 Moto G의 후속 모델입니다. Moto G2는 5인치 720p 디스플레이와 Qualcomm Snapdragon 400 프로세서를 탑재했습니다. 모델 번호는 XT1045, XT1040, XT1039, XT1069, XT1068 및 XT1064입니다.
micro usb port broken...needs replacement
Hello,
My moto g 2nd gen phone charging port is broken. I can clearly see the inside of the port is broken and needs a replacement. Could you please let know the guide for this? and where can i purchase the replacment parts for it?
Thanks,
Anand
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 5개
선택된 해법
This is a difficult one, I would suggest taking it to a phone repair shop.
https://www.youtube.com/watch?v=ycER7MH6... - the link is a video on taking apart the phone itself if you wanted to attempt to repair this yourself.
I am not sure where you could buy a charger port, hence why i suggest a phone repair shop as they would have the equipment and hardware needed to repair this.
Sorry i couldn't be much help, but if this has helped you in any way please accept the answer or score the post.
Wish you all the best
이 답변이 도움이 되었나요?
점수 4
댓글 달기
http://www.etradesupply.com/motorola-mot...
Charging Port for Moto G2 .....
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Moto G2 charging port locates on the motherboard by soldering, so it is hard to replace it by DIY repair work, you'd better send it to the repair shop for help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My local phone / computer repair shop just confirmed for me that the solder used to connect the micro USB port to the motherboard is a higher temperature solder than what's used for the other components, intentionally to make it darn hard (nearly impossible) to replace this “wear item” in order to sell more phones.
This shop won't even attempted this repair any longer after several failed attempts and they consider themselves experts at micro soldering.
Sucks that phone companies have all figured out this dirty little bit of truth (that we are not surgically precise in our connecting and disconnecting our cords) and so they are getting away with building in and selling planned failure.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i have motorola moto g2 xt1068
my phone have 2 problem
1 my socket charger of board is broken that connect to pc and charger but not charging
2. my phone is starting up and after 1 minutes shutting down automatic
now i have one question that if i change my socket charger of board my shutting down problem is fix?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Anand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 23
전체 시간: 24,927
