주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Optimus G는 2012년 9월 19일에 발표되었습니다. LG전자가 설계 및 제조한 스마트폰입니다. 미국에서는 AT&T와 Sprint를 통해 이용할 수 있습니다. AT&T는 8메가픽셀 카메라가 탑재된 E970 모델을, Sprint는 13메가픽셀 카메라가 탑재된 LS970 모델을 제공합니다.
How to get back the IMEI
My LG Optimus G has lost the IMEI after dropping from the chair. The IMEI in My Phone Identity menu said "Unknown" and so did the IMEI SV. The networking is normal, I can access the internet but I cannot have the phone call although the phone has simcard and memory card. My floor is made of ceramic. What can I do to repair my phone.
A repair shop told me that the hardware is the cause, not the software. But they don't have this kind of hardware.
If the hardware is the cause, could you please let me know what is it, what is the product code, eg, so that I can identify it and buy it online.
Thank you,
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 9개
선택된 해법
It is not a hardware fault. IMEI is a file in root. use imei writing tool and write the original imei.
Try below steps,
In the dialer , type- *#197328640# or *#*#197328640#*#*
>You will be prompt into the Command mode, On the screen provided , Select on Common , normally option 6
> Now Select (FTM) Option 1
>FTM is for debugging and testing .,(Field Test Mode)
>If (FTM) is on, you will have to turn this OFF
>As soon as your turned this off your NULL or altered IMEI number will be restored
이 답변이 도움이 되었나요?
점수 3
댓글 달기
i have lg MS500 ,showing imei null.
how to change imei no back to original?
Update (08/22/2016)
i tried the above but not working on my phone too.
can any one sujjest what to do?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I lost my phone (LG optimus G pro) and I know it IMEI number of my phone. I want to find my phone is location. please assit me. Thanks
이 답변이 도움이 되었나요?
점수 1
댓글 달기
yes this a hardware issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
this not working on my phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
not working to my LG P970, do I need to insert a SIM card?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone is screen lock i have no mobile box how can i see my phone imei model no LG Optimus G E975
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I've never heard of something like that happening. Are you able to put in the IMEI manually? The IMEI and other numbers may be written near or under the battery. Have you tried a Factory reset?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check if your Baseband is not Unknown,restoring IMEI is easy.
If Baseband is Unknown then you will need nvram from working phone (same model).After you get Baseband root your phone and use "MTKdroidTools"
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
tin trinh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 30
전체 시간: 25,957
